Group: Administrators Last Login: Today @ 1:39:24 PM Posts: 8,770, Visits: 13,573 |
| dnvntr (4/18/2012)
Hi, I'm getting the same problem. I have a CTA PRO trial version and when I upload images as props, they all look very blury except when I uploaded the face portion. Like Veteran, you can see here the comparison that the images I did on photoshop is very different from when I imported a few images to CTA (the window and the background portion) there's a huge difference between the two... files keep getting uploaded blurry. Any other solutions? I took note that it's got to be between 4000x2000px and the image was less than this, but the image still got blurry. I didn't upload as background because that made it more blurry so I used as PROP instead.. hope anyone can help.  thanks, Hi.. Please try opening Preferences (CTRL-P) and change the Max Real-Time Map Size to something like 4096 x 4096 or at least 2048 x 2048. You will see a noticable increase in sharpness at these settings.
Peter Edwards Forum Administrator www.reallusion.com |
Veteran
Group: Forum Members Last Login: 1/16/2013 9:13:16 AM Posts: 228, Visits: 490 |
| Peter (RL) (4/19/2012)
dnvntr (4/18/2012)
thanks,
Hi..
Please try opening Preferences (CTRL-P) and change the Max Real-Time MapSize to something like 4096 x 4096 or at least 2048 x 2048. You will see a noticable increase in sharpness at these settings.
Just a question here...the settings you have suggested "Max real time map size" (and maximum image import size) have ZERO to do with the export right? These are just settings for editing, but have NO impact on the quality of your export.
Is this correct?
Thanks....
Win 7 64 bit - DirectX11 - NVIDIA GeForce GTX 560 Ti - 16 GB RAM - Intel Core i7-2600 @3.40GHz 3.40GHz |
Group: Forum Members Last Login: Today @ 4:58:52 AM Posts: 6,536, Visits: 13,001 |
Is this correct?
No, because you get the image quality ( export result) what you see in the preview.
liebe Grüße vidi
„Um ein tadelloses Mitglied einer Schafherde sein zu können, muß man vor allem ein Schaf sein.“
Albert Einstein
