iClone 5.1 & Microsoft Kinect SDK Beta2 Feedbacks
Posted By Visconti 13 Years Ago
Posted 12 Years Ago
Distinguished Member (116.0K reputation)Distinguished Member (116.0K reputation)Distinguished Member (116.0K reputation)Distinguished Member (116.0K reputation)Distinguished Member (116.0K reputation)Distinguished Member (116.0K reputation)Distinguished Member (116.0K reputation)Distinguished Member (116.0K reputation)Distinguished Member (116.0K reputation)
Last Active: Yesterday
Posts: 22.7K, Visits: 35.7K
MakeMeZing (2/27/2012)
I updated to v5.12 and have now been unable to use the mocap to produce movements which involve the avatar moving in two planes (e.g. hopping, turning etc) is it possible to revert back to v5.11 as I was able to capture these movements in that?
Thanks
Which Kinect sensor and driver combination are you using?
MakeMeZing
MakeMeZing
Posted 12 Years Ago
New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)New Member (21 reputation)
Last Active: 11 Years Ago
Posts: 6, Visits: 118
I'm using a Kinect for Xbox sensor and Micorsoft Kinect SDK Beta. This is what the RL support told me to use and worked fine with v5.11 but then I lost the range of movement when I updated to v5.12
Posted 12 Years Ago
MakeMeZing (2/28/2012)
Thanks for clarifying.
I would advise contacting Support about this issue as they may have a solution. You should be able to use v5.12 with the Microsoft Kinect SDK Beta 2.
If you really want to drop back to v5.11 then you can do so but you will need to uninstall iClone5 first. You can then download the latest v5.1 installer from your Account and then only patch to v5.11.
MakeMeZing
MakeMeZing
Posted 12 Years Ago
I've emailed support again as I did flag it to them 2 weeks ago so hopefully they'll have some developments.
Thank you for your help Peter
hgagne
hgagne
Posted 12 Years Ago
Last Active: 9 Years Ago
Posts: 90, Visits: 441
MakeMeZing (2/29/2012)
I'm using IC5.12 and have been successful in using the XB360 Kinect with both the OpenNI and MS SDK BETA2.
I did have to remove the OpenNI/PrimeSense driver packages from Program & Features (aka Add/Remove Programs) as well as the RL Mocap package before installing the RL MS SDK BETA2 Mocap package.  To switch back, I removed the Kinect related packages and the RL Mocap package.
Once I received the Windows Kinect devices that I ordered, I removed all the previous Mocap related packages, installed the RL Windows Kinect Mocap package which installed the retail MS SDK with success.
__________________________________________________________________
DELL Precision T7500 & Precision M6600
Dual Quad Core XEON 2.13 GHz, 12 GB RAM, 1 TB HDD's
nVidia Quadro 5000 (2.5GB RAM), Driver 320.49 (2013.07.03)
Windows 7 Ultimate (64bit)
Dual 22" LCD Monitors
iClone 5.5 Pro, 3DXchange 5.5 Pipeline, CrazyTalk & Animator Pro
Autodesk Entertainment Creation Suite 2014
Adobe Production Premium CS6
12 Years Ago by hgagne
MakeMeZing
MakeMeZing
Posted 12 Years Ago
I have now removed everything and reinstalled iClone v5.11 pro, mocap v1.1 (MS beta) and MS kinect 1.0 beta2 SDK. Do I need to install anything else e.g the primesense driver to get the mocap working properly??
Please note I can get the mocap to work its just the character is not picking up turning motions (which the demo shows that it can http://www.youtube.com/watch?v=CF8C2A1tKtg - 37 secs in)
Thank you for your help so far
Posted 12 Years Ago
Just to add you should be able to find answers to most mocap related questions HERE if you are still encountering any installation issues.
