Html flash is not working
12>>
Html flash is not workingExpand / Collapse
Posted 10/12/2008 4:28:31 AM
Newbie
Last Login: 10/15/2008 3:27:02 PM
Posts: 2, Visits: 4
below, files are needed to run my presentation online.
I have a folder name: test_Data. inside this folder i have 4 files.
AC_RunActiveContent.js
FlashSwf.swf
test.flv
testStandby.flv
Outside this folder i have 1 html file which contains flash embedded presentation.
test.html
But problem is that i only see play button and stop button. Ican see and hear prsentation localy on my computer but not online on the webb. What is going on?
i only see buttons its mean that my 2 files: test.flv, testStandby.flv are not connected (imported online shortcut) to my presentation. But why?
am i missing something or what?
Post #10709
Posted 10/12/2008 1:27:51 PM
Last Login: Yesterday @ 11:51:21 PM
Posts: 3,801, Visits: 6,294
Can you give a link to the test web page? This will help to understand the problem better.
Peter Edwards
Post #10720
Posted 4/14/2009 11:42:13 AM
Newbie
Last Login: 4/16/2009 8:06:10 AM
Posts: 7, Visits: 17
Was this problem ever resolved? I am having the same problem. Works Locally but not on the web. http://netspaceads.com/lion.html
Any ideas? I uploaded all the necessary files.
Post #18035
Posted 4/15/2009 9:11:09 AM
Veteran
Last Login: Yesterday @ 1:44:48 PM
Posts: 291, Visits: 493
***DISCLAIMER *** Below is the information I was given from the Adobe Flash Support Forum when I encountered a similar problem with flv files not playing in non-local browsers:
In order to have Flash movies play correctly on non-local computers you need to have the following files on your server site:
In the root folder of your server site:
FLVPlayer_Progressive.swf
Clear_Skin_1.swf
In the Scripts folder of your server site:
expressInstall.swf
You can find these files by Google or go to the Adobe Flash Forums and search on this topic.
Hope this helps-
Cathy
If it's Wacky it's in the Wiki - iClone's Missing Link Wiki - Where All The Secrets are Stored!
The Undisclosed Studio - Where Mysterious Things Happen
Post #18083
Posted 4/15/2009 9:34:49 AM
Newbie
The files I have are the files that CrazyTalk put there.
flashSwf.swf
AC_active content.js
two FLV files one for standby and play
I have used swf files not did not need the express install files
Post #18085
Posted 4/15/2009 10:45:19 AM
Veteran
Group: Senior Forum members
Last Login: Yesterday @ 6:04:34 PM
Posts: 178, Visits: 2,661
lagreen (4/14/2009)
According to your page the path to your video files is
/lion_Data/lion.flv and
/lion_Data/lionStandby.flv
Direct requests of the files both result in a 404 page not found error. Since you double-checked the files have been uploaded correctly I assume the FLV mime-type has to be added to the MS IIS server configuration.
Hope this helps.
Use this discount coupon code R5KDK to save $10 on Postbox!
Use this discount coupon code RKDBIZ to save 10% on Hover!
Post #18092
Posted 4/15/2009 1:51:57 PM
Newbie
did not know I had to do that. I thought the SWF player took care of that.
Any idea what file I point the executable to on IIS?
Post #18103
Posted 4/15/2009 1:53:42 PM
Veteran
Did you follow the link in my post above?
Post #18105
Posted 4/15/2009 2:05:21 PM
Newbie
you were right!! (did not think it was a link, thought underline for emphasis)
I figured out how to set up a new mime type and now it works.
Thanks a bunch, very helpful
Post #18107
Posted 4/17/2009 1:35:31 PM
RKD (4/15/2009)According to your page the path to your video files is
Hope this helps.
Hi RKD,
Great to see you back on the forum again.
Thanks for helping out with this problem. Your expertise in this area is always well appreciated.
Thanks again.
Peter Edwards
Post #18237
12>>
Forum Moderators: Admin, Visconti, Peter Edwards, Spider, JMartin, Phil_20090922184357260, julia - reallusion
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 1:15am
Execution: 0.219. 11 queries. Compression Enabled.
