| | | Veteran
Group: Forum Members Last Login: Yesterday @ 7:56:21 PM Posts: 122, Visits: 881 |
| | Per the tutoral I've downloaded the Sop with Pup model plane into xchange and highlighted the skp route, the next step ask you to id the wheel nodes. How do you id nodes that are not listed by name? The scene tree only id's them as mesh, frontside or backside and there are more than 61 parts listed. Please explain |
| | Hi, You find the parts you need by taking the tick out of each node in turn until just the ones you want are visible. To save you time, just take a look at the written PDF tutorial. This shows you the nodes that you need for the wheel section. Animating Google Sketchup Models
| | | | Veteran
| | Thank you for the info, but this was written for the version 2.5 iclone, is there a tutor for 3.0? |
