iClone5 PDF Manual - Now Available
12>>
iClone5 PDF Manual - Now AvailableExpand / Collapse
Posted 10/29/2011 12:12:33 PM
Last Login: Today @ 1:39:24 PM
Posts: 8,770, Visits: 13,573
iClone5 Pro PDF Manual - Now Available
The manual in PDF form is now available. Please download it from the link below.
http://file.reallusion.com/ic/iClone5_Pro_manual.zip
Peter Edwards
Post #100673
Posted 10/29/2011 8:28:07 PM
Last Login: 3/20/2012 10:43:07 AM
Posts: 61, Visits: 181
Thanks for all your hard work on this! Looks like a great resource. Do you have any plans to make it available 'print-on-demand' via Lulu.com?
________
* MyClone -- free stuff and news for users of iClone, CrazyTalk Animator, and more!
Post #100729
Posted 10/31/2011 4:28:35 AM
Newbie
Last Login: 11/2/2011 10:19:56 AM
Posts: 6, Visits: 101
This pdf file is without page numbers!!! Could you add page numbers into manual for comfortable print this file?
Post #100878
Posted 11/24/2011 6:31:49 PM
torosfx (10/31/2011)
The manual has now been updated and does contain page numbers.
Peter Edwards
Post #103743
Posted 11/25/2011 7:55:12 AM
Last Login: 4/17/2013 4:50:47 PM
Posts: 85, Visits: 413
Peter (RL) (11/24/2011)
Hi Peter,
Please thank the folks doing the documentation for IC5.
Should the UG be revised again in the future, you may want to request that the header margin region moved down and the footer margin region moved up to accomodate PDF viewers (ex: iBooks) - the header/footer regions are currently cropped off as they fall into the non-printing (viewable) region and therefore not displayed.
Additionally, it would be helpful if the TOC behaved similarly to the IC4 UG where one can click/tap (select) an entry in the TOC to jump straight to that page.
I'll refrain from asking for an Index to be added.
Cheers,
____________________________
DELL T7500 (4)
Dual Quad Core XEON 2.13 GHz
12 GB RAM
nVidia Quadro 5000 (2.5GB RAM)
1 TB HDD's
Windows 7 Ultimate (64bit)
Dual 22" LCD Monitors
Post #103811
Posted 11/25/2011 8:23:13 AM
Last Login: Today @ 5:51:53 AM
Posts: 2,531, Visits: 4,217
hgagne (11/25/2011)
Hi Peter,
Cheers,
Try "Foxit", a Free Download PDF Document Reader Program.
Visit www.pinheadhq.com , to read about Pinhead's exploits & view his Clips. Join-in the Projects &/or Submit a "Fun" Clip, having fun yourself.
System Specs:
Quad Core i7 960 3.20 GHz HT CPU (8Threads) on Asus P6X58D-E MOBO. 6GB Kingston HyperX DDR3 Triple Channel 1600MHz RAM, AMD/ATI Radeon HD 5770 1GB Video Card, 2 X Western Digital Caviar Black 7,200rpm 6GBs 500GB internal HDDs & 1 X 500Gb Seagate FreeAgent externalHDD for system Backups
Post #103817
Posted 11/25/2011 10:18:56 AM
Veteran
Last Login: 4/2/2013 6:06:21 PM
Posts: 202, Visits: 2,025
Thanks Peter for letting us know about the update
And a big THANK YOU to the RL people who created the TOC & page numbers.
No more blind hunting for the info!
Post #103840
Posted 12/1/2011 3:32:15 PM
Last Login: 7/23/2012 6:33:19 AM
Posts: 57, Visits: 284
Thank you
I'm just a pigment of your imagination.
_______________________________________
Post #104533
Posted 4/24/2012 6:58:32 AM
Hi Peter,
Do you know if the RL documentation team has any plans to revise the IC5 UG PDF to incorporate the new functionality details once the 64-bit version if IC is released?
Cheers,
DELL T7500 (4)
12 GB RAM
1 TB HDD's
Post #120618
Posted 4/24/2012 2:57:55 PM
hgagne (4/24/2012)
Hi Peter,
Cheers,
The 64bit version of iClone 5.2 has already been released, albeit in a Beta version at present. I doubt that the PDF manual will be updated because functionality wise the 64bit version doesn't add any new features, it is only a performance related upgrade.
Peter Edwards
Post #120663
12>>
Forum Moderators: Visconti, Peter (RL), Bruce (RL)
PermissionsExpand / Collapse
All times are GMT -5:00, Time now is 4:08pm
Execution: 0.156. 7 queries. Compression Enabled.
