Hi
This is just a quick tutorial on how to get a Daz Genesis character with animation into Iclone via FBX and 3Dexchange
1: Load Daz and create you Genesis Character with morphs ….
2: Open the aniMate2 tab under the file menu Window / Tabs. Drag any of the aniBlock animations you wish to use onto the animate2 time line. Right click on the darker Gray colour above the numbers 1 2 3 4 5 6 et.... A menu should appear saying “Bake to studio KeyFrames” click this.
Now open up the Timeline editor under Windows / Tabs and you should see a large number of small black triangles. You should now close the aniMate2 tab.
You may need to alter the Total number of frames in the bottom left corner to accommodate all of the animation.
3: Now go to file and Export and select Autodesk FBX and give it a file name then press save, a dialogue box will appear. Set yours to look like to image below and press accept.
4: Once the export has finished save your project and close Daz Studio 4 and open 3Dexchange pro. You can now drag your Character.FBX file into the 3Dexchange work area. A dialogue box will appear. Set yours to the setting below and press OK. It may then show a dialogue box about exceeding 30,000 face count, just press OK.
5: Once the character is in 3dexchange it will be on its back. Go to the Rotate box on the right and in the first box exchange 0.0 for 90.0. When the character is the right way up press the play button on the bottom of the screen to see your animation. Also at this point you may want to set the Specular of you characters textures to 0 to stop him/her looking like plastic.
6:Click on Auto Smooth to take away any ruff edges then Convert to Character. Just click ok to any dialogue box that appears after, then goto File and export. Below are the settings I use for export, you can save where ever you want but the important things are that the motion files are not moved after export or Iclone will need you to tell them where you put them and that you select ALL under export options.
7: Close 3Dexchange open Iclone, goto Actor/Avatar and Import from where you saved it . Once in right click on your character and goto Perform …..
http://www.youtube.com/watch?v=Qyp1vKeHhuw and here is the vid ... hope it helps
I Make My Mates Do The CanCan For The Amusement Of Killer Robots
13 Years Ago by
bluemidget666
