Junior
Last Login: Today @ 8:35:25 PM
Visits: 88
I downloaded free bvh files from Animazoo.com. When I used to bvh converter to convert the file an import it into iClone, the character's body is distorted, when I apply the motion. Why does this happen? Can someone please tell me what I'm doing wrong or not doing. Thanks.
I tried applying the motion to different character and it happened on every character. Thanks in advance for you help.
sheneka
Junior
Last Login: Today @ 8:40:59 PM
Visits: 215
Welcome to the club.
The BVH converter simply don´t work... even with the scripts that reallusion suply and says at the manual and advertising thats work right.Animazoo, Poser , Motek... SIMPLY DON´T WORK ! and don´t work with no one file that I tried import from others sources.
No convincent answers about the problem from Reallusion and no answer if it will work ok at IClone 3.
I´m very disapointed...
Alemar
Power User
Last Login: 8/20/2008 4:26:56 AM
Visits: 99
To be honest I've given up trying to convert external motions due to the problems you have described. As much as it's time consuming, using the motion editor is the only way I have found where I can get the motions I require. I only edit when I really, really need to, as I know I'm going to be spending time getting it right.
Find the motion closest to the motion you require and edit it, works for me 80%, with shot editing you can get away with it.
Hope this helps
Capemedia
Capemedia is CLOSED 'The Forgotten Children' - Promo Video
Follow Progress Here
Junior
Visits: 88
Thanks for the feedback. This will save me a lot of time. I'll just have to work with what I've got.
sw
Newbie
Last Login: Today @ 6:36:14 PM
Visits: 48
Capemedia (6/24/2008) To be honest I've given up trying to convert external motions due to the problems you have described. As much as it's time consuming, using the motion editor is the only way I have found where I can get the motions I require. I only edit when I really, really need to, as I know I'm going to be spending time getting it right.
Hope this helps
Capemedia
Hence, the need for more presets. Amen.
