bvh motion converter
Reallusion Forum
Reallusion Home      Members   Calendar   Who's On
bvh motion converterExpand / Collapse
Posted 1/4/2008 1:43:01 AM
Newbie
NewbieNewbieNewbieNewbieNewbieNewbieNewbieNewbie
Last Login: 1/21/2008 5:59:43 AM
Posts: 8, Visits: 76
Hi
can anyone tell me about the bvh motion converter in Iclone nd how to use it.
OR
Is there a way to import iclone motion in 3ds max
Thanks
--Meenakshi
Post #2605
Posted 1/4/2008 10:40:28 AM
Tutor
Group: Moderators
Last Login: Yesterday @ 9:29:05 PM
Posts: 1,808, Visits: 3,109
You can find information relating to the BVH Motion Converter from the link below.
http://www.reallusion.com/iclone/bvh-motions.asp
Also there are full instructions on its use in the iClone Help document. Just press F1 from within iClone and navigate to Adding Motion To A Character - Motion - Using BVH Motion Converter.
Everything you need to know should be available from these sources. Hope it helps.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #2611
Posted 1/7/2008 7:38:25 AM
Newbie
Hi
I studied these links but Is there anyway to import iclone motion in 3ds max or any other format(actually I need the animation file in .egg format).
Thanks
--Meenakshi
Post #2645
Posted 1/7/2008 12:14:33 PM
Tutor
Group: Moderators
You can't open iClone motion files directly in 3DS Max and iClone does not allow export of motions into any other format.
You can import motions into iClone in the following formats (extensions): VNS, CHB, HTR, CHA directly or BVH via the Motion Converter.
Peter Edwards
Forum Moderator
iClone Daily Blog
Post #2650
« Prev Topic | Next Topic »
Reading This TopicExpand / Collapse
PermissionsExpand / Collapse
All times are GMT -7:00, Time now is 1:49pm
Powered By InstantForum.NET v4.1.4 © 2009
Execution: 0.172. 10 queries. Compression Enabled.
