It could be improved A LOT, indeed. For now I'm not bothering with ICindigo until it evolves into a local IPR viewport, all 3rd-party plugin compatible. The export scene workflow as is, so tedious, it's faster to pack the scene up into FBX, import export via 3DX and shader-render elsewhere. IF 3DX packs the scene up properly for one's chosen ext renderer, that is.
For the long run, ideally IClone models its external renderer workflow design on its modestly-priced peers, and allow external renderer to make far better use of the iClone "mini viewport".
The IPR viewport should be un/dockable and has classic viewport options. For fast machines,
it can become the main/ the only viewport to work in.The Final viewport should be a floating window like typical plugins. Better still, dockable.
For the lower end machine, IPR render frames should be good enough for final. For high end machine, IPR acts as a typical preview render, when satisfied then use the final renderer.
Daz Studio, the best IPR Viewport of its class (near-real-time, ZERO shader transfer hassle; pause-able, render 3rd party instance hair and instances, via 3Delight a Renderman compliant engine; Viewport is full-featured so can act as a 2nd or the DEFAULT viewport; a FREE update)
OR4C Carrara Octane (near-real-time, more stable than Daz/Poser Octane, minimal shader rework, render native instances but not (WIP) procedural trees or strand hair)
Daz Studio Octane viewport design is also interesting
LuxCore Carrara IPR & Biased Renderer (near real-time, usable across all Carrara "rooms"; surprisingly fast OpenCL for AMD or Nvidia at 25-30sec per usable frame. Some shader rework needed, comes with solid LuxCore shader sets from trans to ref to SSS) Bridge to LuxusCore. Cheap alternative to Octane, current status beta test and free)
Hope that's enough ideas and inspiration for tighter, faster,
more user-friendly iClone Indigo integration.
Cheers
>>> Indie Generalist modeler-rigger-animator <<< Hardware: AlienWare i7-HK 32G GTX1080 2T-SSDs BenqSW320 Wacom-Intuous 3Dconnexion ||| Software: IC6 Pipeline - CTA3 Pipeline - ATK2 - Indigo ||| Zbrush4R8. Blender 2.79. DazStudio 4.9. Carrara. Poser. Octane.
9 Years Ago by
Bellatrix
