Darren01 (1/20/2015)
thanks for the replies guys
Colour - sorry forgot to mention I'm using a G3 character.
With the 'edit motion' that you demonstrate in your screen shot - that would mean I would have to key frame the arm swing manually wouldn't it ? (which would be a fair bit of work) Or is there just a way I can just limit the effect/travel of the automatic swing motion ?
thebiz - no I'm not using the motion puppet. I've just right clicked the avatar and chose the 'walk forward' motion. I don't know much about the modify motion panel, I just tried it as an option when I right clicked the motion in the time line. But it doesn't seem to apply to preset motions ie 'walk forward'"
"Colour - sorry forgot to mention I'm using a G3 character."
Which one, Darren?
If I have it, I'll play-around with it.
In the meantime, here's a very quick Screenshot., Follow the red underlining.
1) Violet G3
2) Drag Timescale Scrubber to Walk Forward left hand arm full extent.
3) Edit Motion Layer; Rotate Left Arm down a bit.
4) Repeat for Right Arm.
5) Play-back. Arms don't "Power Walk".
6) Collect Clip (If you want to) As new Walk Forward Motion Haven't tested that yet. But should work .
7) You can use the Time Warp Curve Editor, to slow Motions-down, reducing the Power Walk. (More on that, if you want).
Screenshot:
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS.
9 Years Ago by
colour
