rampart (10/21/2014)
Working on project with timeline...65bit.
1) I added an avatar, it walked path and stopped. I selected the avatar and tried to use the rotate and move tool it would not do anything. I was trying to turn the avatar 90 degrees. This doesn't make sense to me, because I select other avatars in the scene and they will rotate and move.
2)When I use edit motion layer the program most often goes to all white screen and then it comes back sometimes, sometimes not. I have started saving project before I use edit motion layer everytime.
3)Sometimes the screen for the iclone page goes white. Then it comes back if I jsut wait.
1) If Character's on a Path, it's Attached to it. IMO, you can only Move/Rotate the Path &/or the Control Points, via Edit Path / Right-Click on Control Point (I "think", without checking). Not the Character. You can also Rotate the Character via Follow Path Axis from eg; -y to y.
2) Sounds like a GPU issue. Doesn't happen here & I've never seen prob Posted before.
3) Same answer as 2).
Anyone-else?
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS.
10 Years Ago by
colour
