yetzirah
yetzirah
Last Active: 9 Years Ago
Visits: 61
Ive gone to the tutorials and after getting mocap plugin 110 ms-- i still can't get past calibration. On the demo, it shows a sort of xbox interface-- with the floating virtual hands on the screen for finalizing a pose. I don't get these at all. Is this for only a specific plugin or is it in all of them? I basically just assumed that when all the signs to the left are green after the countdown and striking the H pose, that its all that was necessary. I even recalibrated it by hitting the central calibration button. Its like i dont have away to interact with the buttons on the screen, but it says the pose was successfully captured. After that, i walk to the screen(and don't know if im jinxing the whole operation) to hit connect on the mocap tool. It says its connected, but no interaction with the avatar, even though i have mocap and motion selected. SHould i be under avatar instead of motion once i get the screen up? I hope i explained what im doing well enough. Any assistance would be greatly appreciated. I'm planning on doing alot of choreography stuff that may really assist in the animation area of iclone, fight choreography exct, being that ima martial artist(A tai chi and dual weaponry pack may be in the works soon enough) Thanks.
yetzirah
yetzirah
Visits: 61
Also, im trying to follow this specific link http://www.reallusion.com/iclone/help/iclone5/Pro/default.asp?page=08_Animation/Device_Mocap/Using_Mocap_Device_Plug_in.htm to get it right. I can get to step 3 where the icons are all green BUT no dummy appears so i can line up the H pose. Instead, i turn either red green blue exct-- Ive gotten entirely in the green, and the box below the mocap plugin says "initial pose captured.", thats it. I dont get any floating icons like in the video that look like a kinect interface for xbox. Just 4 green icons at the right. Is someone suppose to be in the room with me to activate the console? I also have the box checked for body command(which im guessing is supposed to have to do with the floating interface with the hands-- Again-- i hope someone can help-- Yes i am registered and all that, bought my own copy, yada yada-- ive put over 2000 into my stuff in last 8 months. Take care.
yetzirah
yetzirah
Visits: 61
ALSO-- ive removed prime sense, openni and nite, few other things including the sdk(all of which i was under the impression i needed for it all to work, but there really wasnt such great help or tutorials)-- and then i reinstalled the mocap ms 110, entered serial-- but the patch is saying that mocap is not installed? I kinda feel like Professor Frankenstein in that scene where he stabs his pen into his thigh.... kfshdfkshfkshfksdfhsdksh. HELP!
planetstardragon
planetstardragon
Last Active: 2 Weeks Ago
Posts: 11.5K,
Visits: 45.9K
lol we got you! first the obvious - you have a power supply on your kinect correct ? I would think so, because you seem connected , but we have to go through the routine to eliminate possible issues, starting with the most obvious possible errors. 2nd question, you've updated your iclone to the latest versions right ? - double check anyways - click the ? and "check for update"
yetzirah
yetzirah
Visits: 61
Yah i have the power supply, lol. Furthermore-- you said "Go to update"-- Im guessing youre referring to update from within the program on the opening screen? I went there and it gave me a browser window, i clicked upgrade and it tells me to login-- From there im at the register product and upgrade page. I had my serial resent and it will not accept the serial number. Tells me to contact the support team. Meanwhile i have a ticket open in regards to this and all i get is a link to the sdk 2 beta version for xbox 360 kinect which ive dl and redl several times but of course NOT BEFORE uninstalling all the other things as well. I did some research and it seems that there is a driver conflict but it has more to do with what the kinect uploads once its connected more than the downloads-- It shows in the tutorial that i should have a kinect "motor" under devices-- and that never happens. Only under the prime sense driver section is where the kinect motor driver appears but once i plug in the kinect, its replaced-- so i attempted to delete and uninstall the drivers from the device manager itself(kinect audio array, kinect cam and kinect device(not reading motor), and once i did that, i have the primesense section under device manager reading that those 3 required drivers are present, HOWEVER, the mocap plugin cannot read the device at this point and tells me it is not connected. So as you can see, ive been working at this from more than one angle, lmao.
yetzirah
yetzirah
Visits: 61
And btw, that upgrade page is a trip, lol--- It can't just say YOU ARE UP TO DATE, CONGRATS! Instead.. it says....(with robotic cyborg voice) Installed product....ICLONE5 PRO EDITION Installed version...5.51.3507 official release verion...5.51.3507 Nehow, after 5 minutes of contemplation(of the deepest kind of course), i gather this means i am up to date... haha. Another lap around the merry go round we goeth i suppose.
Last Active: 4 hours ago
Posts: 22.6K,
Visits: 35.6K
Hi Yetzirah I have replied to you via Support regarding your Mocap Device Plugin problems. Please can you check in your Member Account for my reply and continue to reply there. Thanks.
yetzirah
yetzirah
Visits: 61
SUrely, Peter-- Appreciated-- would be noice to geet it done by now. Peace!
yetzirah
yetzirah
Visits: 61
Just figured i need all the help i can get with this and that others are having similiar issues.
