gcshep (8/27/2014)
Ok I surrender come on Reallusion gives a clue where is it hidden.If you use Collect Clip with a prop that has transform data, the animation will be embedded into the Prop. The animation data will not be saved locally.
However if you use Collect Clip with a character that has motion data, then you will be prompted to save to iMotion format in the folder of your choice.
If you need to edit the animation in the Prop you can take it into 3DXchange5 and make changes in the Perform Editor.
