wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
You can do it in Daz studio alone too. use the polygon group editor or what ever it is called now they keep changing names to select hide delete hidden surfaces under the right click can by surface name or select polys line it up and size to fit Genesis, hide genesis by clicking eye icon export it with no hidden clicked to get it in correct default position re import delete original use transfer utility
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
here you go
rcsinger29
rcsinger29
Last Active: 3 days ago
Visits: 3.0K
How do you edit the mesh where necessary to fit the shape? Do you use deformers? Getting the clothing to "fit" the avatar without mesh editing has proven to be a challenge to me, this is why I use max to model/edit the clothing against the genesis shape before exporting.
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
I just resized and used smoothing collision
rcsinger29
rcsinger29
Visits: 3.0K
wendyluvscatz (6/22/2014) I just resized and used smoothing collisionPlease explain?
10 Years Ago by
rcsinger29
theschemer
theschemer
Posts: 1.4K,
Visits: 2.9K
wendyluvscatz (6/22/2014) here you go
Thanks Wendy, That will come in handy. Nice tutorial. TS
wendyluvscatz
wendyluvscatz
Posts: 2.5K,
Visits: 19.4K
rcsinger29 (6/22/2014)
wendyluvscatz (6/22/2014) I just resized and used smoothing collisionPlease explain? look under edit geometry add smoothing modifier then in parameters set genesis as your collision item
rcsinger29
rcsinger29
Visits: 3.0K
Thanx, I'll give that a go.
timmyfarrell
timmyfarrell
Visits: 70
Anyone having problems with Gen2 eyes as well as lashes in 3dX? I'm forced to do all kinds of tricks with diffuse, opacity and tiling to get them close to original.
