Hi Rampart,
Is the audio only out of sync in the exported video or is it also out of sync when you preview in CT7?
If it is only when exporting, then it could be the video format you are using that is the problem. For example if you are exporting HD video in uncompressed AVI, then this will put a lot of strain on your computer and if it can't keep up, the audio will slip out of sync.
Try exporting in WMV format or AVI with a codec and see if the problem goes away. You can also try outputting at a lower resolution to see if this resolves the problem.
Tip: Try defragging your hard drive. If the drive is badly fragmented then this can cause sync problems.
