dddu88
dddu88
Last Active: 8 Years Ago
Visits: 88
Hi All,
I am trying to run export fbx from 3dxchange to unity, one issue is on the dialog box, I check to include geometry and all, then check to include animations, then from right side dropdown box select Unity, after unity is selected, it automatically uncheck "include animations", when I check to include animations, it automatically switches from Unity to Custom on the right side dropdown box, so I can not have both "include animation" and "Unity", one work around is to export geometry and animations separately, but I like to put them in one fbx file.
My 3dxchange 5 is most recent, since I just bought it last month.
Please help and thanks in advance.
Dave
vidi
Last Active: 2 Weeks Ago
Posts: 10.8K,
Visits: 40.2K
when I check to include animations, it automatically switches from Unity to Custom on the right side dropdown box, so I can not have both "include animation" and "Unity", one work around is to export geometry and animations separately, but I like to put them in one fbx file . Why do you not tried it to import in Unity , then you will see it works
dddu88
dddu88
Visits: 88
I of course tried, I only see Geometry, no animations, I have to go back to 3dxchange and uncheck geometry and check animations to export animations, they are in separate files, each animation is in separate file. I like to have the Geometry and all animations in one file. Thanks Dave
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
try making a taffy ? basically you add all your motions to one large file - then you can import and truncate that file as needed. I found it necessary actually in my own scenario as Unity seems to make motions even shorter than what is exported from 3DX5, so I couldn't effectively create any loops in iclone that would translate exactly in unity. Not iclones fault though - unity simply autochanges stuff - further unity has some cool tools to truncate and loop quickly anyways - so it was just a change of workflow.
10 Years Ago by
planetstardragon
vidi
Posts: 10.8K,
Visits: 40.2K
Have you realy tried this ?
dddu88
dddu88
Visits: 88
Oh, I tried with checked Save One Take Per File, I will try uncheck that.
Thanks Dave
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
Happy Easter Sunday to you too swoop! then your vast knowledge of bvh and 3D should have posted here long ago to help the author of the thread, for me, unity autochanged stuff - but i never said it was impossible to fix, in fact i said unity had some nice tools. your attempt at the arch villain dramatic entrance was too much, too little, too late, and you tripped on your cape again! Always a pleasure to see you all the same.
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
Hi swoop, let's try an experiment, let's travel back in time to when the original author of this thread was asking for help! play along! -does time travel fingers effect- Cheers!
10 Years Ago by
planetstardragon
Last Active: 27 minutes ago
Posts: 8.1K,
Visits: 60.5K
@ sw00000p, All my work tends to go in the input to iClone direction, being just a hobbyest and all. Never had any interest in resource output from iClone. Not really any help here, sorry.
