iclone 2.5 issue
Reallusion Forum
Reallusion Home      Members   Calendar   Who's On
iclone 2.5 issueExpand / Collapse
Posted 10/20/2007 4:32:23 PM
Veteran
VeteranVeteranVeteranVeteranVeteranVeteranVeteranVeteran
Last Login: 1/1/2008 12:53:52 PM
Posts: 72, Visits: 168
Hello,
When i selected and modifed a character and rotated it , it worked fine. But now when I add another prop and try to rotate it, why does the character also rotate and not remain still, although I'm only trying to modify the prop and not the character
Post #1295
Posted 10/20/2007 6:23:21 PM
Veteran
The same thing is also happening when I have a prop of ball and a 3d scene. Although the ball prop is selected and when i try to use the mouse to pick and move it, the ball doesnt move but the camera moves
Post #1296
Posted 10/20/2007 8:41:22 PM
Skype ID= learn.iclone
Skype ID= learn.icloneSkype ID= learn.icloneSkype ID= learn.icloneSkype ID= learn.icloneSkype ID= learn.icloneSkype ID= learn.icloneSkype ID= learn.icloneSkype ID= learn.iclone
Group: Senior Forum members
Last Login: Today @ 7:37:41 AM
Posts: 240, Visits: 1,180
To move items you use the MODIFY Tab, not the view screen.
As far as the 1st error you stated, are you certain you have the right item selected and that it isn't attached by nodal selection to the Character?
Check your timeline for what is actively selected. Movement of the mouse while dragging on the view screen moves the camera in the scene, that's the whole point, so you can adjust for different angles and camera positioning.
Cricky (Leave me a voice mail if you like.)
If you hover over the Clips below that Pop up...you get a Preview
Post #1300
« Prev Topic | Next Topic »
Reading This TopicExpand / Collapse
PermissionsExpand / Collapse
All times are GMT -7:00, Time now is 12:16pm
Powered By InstantForum.NET v4.1.4 © 2009
Execution: 0.203. 15 queries. Compression Enabled.
