THE MOTION PUPPET FEATURE
The motion puppet feature is activated using the new "Motion Puppet" button available from the Character Motion panel. IC5 comes with a series of preset scripts representing standard human IK motions LOOPS presets such as for Running or Walking toon style etc. The analogy of these Scripts would probably be the Crazytalk CTS scripts for facial animation but these new scripts are for Body animation.
So you can apply these motion loop scripts to a character Body and then use sliders in the Motion Puppet Panel to adjust the different parameters of the actual motion cycle. Using this feature, you can give an entire new style to your character walk or run etc... Once you have fine-tuned your character motion script, you can save your work as a new script for later use.
The typical use of this feature would be to accentuate the walk motion of a Toon character.
This feature will provide great time saving to the task of animating your character and also give you the ability to stylize your character moves.
THE DIRECT PUPPET FEATURE
The DIRECT Puppet feature is also activated using the new "Direct Puppet" button available from the Character Motion panel. the simplest way to describe this feature is to compare it to the current IC4 Facial Animation Puppetry. The Direct Puppet feature is to the body what the Facial Animation Puppetry is to the face.
When you activate this feature, you have a side panel representing a Human Body with nodes and IK constraints. You can activate or lock nodes from the Ik Chain and then animate the remaining skeleton parts by moving your mouse much in the same way as you would to do facial Animation by locking and activating certain parts of the face and then aminating the face using your mouse..
A sample use of this feature would be to have a character sitting in an electric chair, you would lock hands and feet from moving as they are chained to the chair, activate the other body nodes of the IK chain and then, vibrate your mouse to simulate the body going into heavy convulsion during the electric shock scene.
Quite effective !
Come and visit my store by clicking on the banner below.
13 Years Ago by
Bigboss
