FBX is always imported as prop. To convert, make sure your character's root is selected.
In the Modify panel on the right, there is a section called Character (press "N" to go there).
There should be an option Convert to Non-standard.
Click that and you should then be able to start to process to convert from prop to character.
Here is a tutorial on how that is done:
