gerdich
gerdich
Visits: 525
It opens, shows the workbench and immediately closes. The computer is very new, with a dual 1080 gtx.
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
if it's a new computer you built, try uninstalling, cleaning the registry then re-installing. if it's a factory built computer, go to msconfig, and try disabling some of the extra programs you don't need, which are eating up your ram with features you never really use anyways. 1 of 2 things is happening, bad install, or a software conflict that is preventing 3DX from starting normally, also make sure your anti-virus didn't false positive the 3DX software .....several anti virus are flagging 3DX as a virus, and auto cleaning it....that will cause this type of error too.
gerdich
gerdich
Visits: 525
It´s a new computer from factory. The task manager says that 5.2 GBytes of 32 GBytes are used. Switching off the antivirus didn't help either.
7 Years Ago by
gerdich
duchess110
duchess110
Posts: 2.0K,
Visits: 15.5K
In the past some have found that checking this C++ has solved their problems. C++ Redistributable Package for Visual Studio 2012
Duchess Designs Store
7 Years Ago by
duchess110
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
yeah, what duchess said, and disabling the anti-virus wont help if it already did something to the files, best way to check that is look at the av history and see if it did anything. another one to check is your direct x software - see if you can find any errors there as well. at this point, the idea is making a list of things that can cause this kind of error and ruling them out one at a time.
Make sure you've updated the drivers for those video cards (even if the factory installed them, there are most likely already newer drivers available).
Last Active: 4 hours ago
Posts: 15.7K,
Visits: 30.5K
Kelleytoons (7/14/2017) Make sure you've updated the drivers for those video cards (even if the factory installed them, there are most likely already newer drivers available).Also make sure they are the NVidia drivers, as sometimes MS installs the Windows version. There is an option in Windows 10 to ensure that Windows Install doesn't touch factory drivers.
gerdich
gerdich
Visits: 525
Microsoft defender protocol files show no problem. Microsoft Visual C++ 2012 redistributable 11.0.61030.0 repaired for x64 and x86 dxdiag shows no problem
3dxchange 7.0 updated to 7.01
The workbench still crashes but the conversion from iclone and cc still works.
gerdich
gerdich
Visits: 525
I ve got the newest drivers from NVidia. May the drivers for the monitor be an issue? Or may the audio drivers may be an issue?
7 Years Ago by
gerdich
