bruceberg
bruceberg
Visits: 500
I'm having an issue with the 3d heads I create in CrazyTalk 8 from a photo. After I finish my head, I select send to CC, but it sends them to CC1, not CC2. I wondered if I needed to uninstall CC1 to make this happen, but was hesitant to do this. I did a quick search here for the answer, but came up short. Anyone know how to achieve this? Regards...Bruce
bruceberg
bruceberg
Visits: 500
Hi Gang...It just dawned on me to check the CrazyTalk forum for enlightenment. Sure enough, there it was. I will be fixed in the first update and until then I need to drag and drop in CC 2.1. Sorry for the waste of time. Regards...Bruce
duchess110
duchess110
Posts: 2.0K,
Visits: 15.5K
There is no need to uninstall cc1 as it is a known issue and CrazyTalk8 needs an update. Hopefully RL will not leave for to long. The workaround is to save the Head to somewhere on your pc that you are happy with then inside CC2 import the head that you saved.
Duchess Designs Store
Last Active: 3 hours ago
In a case of perfect timing, we have today released CrazyTalk 8.11. If you install the update CT8 will now correctly send your heads to Character Creator 2.
bruceberg
bruceberg
Visits: 500
Thanks Peter, for the heads up!
Posts: 10.8K,
Visits: 40.2K
If you install the update CT8 will now correctly send your heads to Character Creator 2. I'm interested, I and duchess are the only ones where it do not work correctly ? The new update is installed of course
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Also with me the head export of CT 8.11 to CC 2.1 flawlessly But unfortunately no export now goes to CC 1.51. If you do not want to use CC 2 (or can, because it can not use IC 7)For which Ct 8.11 is quite useless for the headset for the CC now greeting Postfrosch
7 Years Ago by
Postfrosch
