Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
I am trying to achieve a fireball that fades out. I have found multiple particle emitters that create the fireball. So far no issues. The problem that I can't seem to solve is that I would like the fireball to grow in size as it fades out (i.e. increase scale as opacity is reduced). However, the particle emitters don't have a scale option. Most of them have a size but the size is not recorded on key frames so setting it on any key frame changes it for the whole project. I even tried making the emitter attached to a dummy parent which I scale up. Typically that causes attached objects to also scale, but the emitter didn't. Any suggestions on how I can achieve my goal?
Last Active: 43 minutes ago
Posts: 9.1K,
ANY suggestions? Or just those that relate to particle emitters? I'd use a billboard with footage, free, from here: http://productioncrate.com/They have some great explosions, including some very nice fireballs (that do fade out). And you could scale the billboard as you wanted.
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.2K
Actually You can't scale the emitter. You have only 4 keyframes to scale the particles thru the life (frame). About Particles , this is the only update feature now (before mirror) I expected for Iclone. All what I need for my pipeline will be in the 7.1
7 Years Ago by
mtakerkart
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
It looks like particle emitters also ignore other objects. I posted on this elsewhere but I tried to confine the particles to a mesh by placing the particle emitter inside the mesh...no go. Then I tried to have them at least shifted by an object mesh so I placed the emitter under an object...again no go. The particles seem to go through any object they encounter as if it was not there.
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.2K
Yes that's thrue Lord. There's no collision detection on this particle system. What we need for the next particle system is: Point Cube Sphere Mesh For the shape of the emitter.
Beam Trail Point
Collision detection Sprite atlas as texture
Shape over speed Vectorfield
Etc...
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
I did find a way to somewhat do what I wanted... I found out that if you turn an emitter off, it stops emitting but any particles already emitted remain until their life cycle ends. As such, I gave the particles an extended life and a larger volume and then turned the emitter on briefly and then turned it off. This generated a lot of initial particles which slowly died out which caused the appearance that I was going for.
