Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Since now all the new IC 7 cheers (understandably) But there is a user who can not use this program (at least not completely, for example, the graphics card Nividia 960 apparently too small, therefore no GI possible and new purchase at the time not possible computer is only 1 year old) they are dependent on ICone 6. Get IC 6 users the possibility to send avatars to CC 2. If I from IC 6 an avatars to the CC send ends it always in the CC 1.5. So I can use the CC 2 only indirectly (which is very bad) Best wishes from Germany Postfrosch
Last Active: 4 hours ago
Hi Postfrosch, Character Creator 2 is primarily designed to work with iClone 7 (both PBR enabled) where as Character Creator 1 was designed for iClone 6. However you can still use the File > Import option of Character Creator 2 to import your iClone 6 CC avatars. Regarding your system not being up to running iClone 7, have you tried this with the trial version? I have seen very good results using the GTX 960 without requiring too many sacrifices graphically. You may be surprised at how well it performs.
Posts: 9.1K,
I had the 960 before I upgraded to the 1080 and it worked just fine -- the only limitation was memory (IIRC it only had 4GB) but otherwise GI, IBL and PBR all functioned great (but be sure you have the latest video drivers installed).
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Hallo, thanks for youer answers @kellytoon I would also ne ne ne card to treat. My computer is only 1 year old and otherwise amply equipped. But as a pensioner, I have to keep my money more together than before @Peter Yes, i work only with IC trial. Next month i buy IC 7. I have all Versions von IC 2 Studio - IC pro (inl. all 3dx pro Versions Its nice thats you come back. It*s very good so Greets from Germany Postfrosch (Werner)
