quinsyr (5/30/2017)
Hello, when I try to load one of my saved scenes I created in Iclone 6, I receive this message "Failed to load the file" Is there anyway to fix that?
Thank you
The only remedy I found that sometimes works is to launch iClone, then load a project that will load correctly, and then try to load the project that would not load.
BTW, are you trying to load in IC6 or IC7 (in case you have the pre-release)?
