Waterlane Studios
Waterlane Studios
Visits: 308
Hi - My decal tabs have no options for images to be 'input'. Can anyone tell me why this is? This is working fine in CC1.5 but not in CC2 I've just installed the latest version of CC2 and 'Essential Morphs' Suggestions Please - I want add my own decals.
Last Active: 27 minutes ago
Posts: 9.1K,
It works for me. The input tab is below all the map tabs -- the default on the first decal for jeans is "hole1" but then you can scroll down until you hit "input" at which point the diffuse will show up just fine.
Visits: 60.5K
Try running the "1-Click Verification" in the help menu. It looks like it is not recognizing the "Essential" pack. Do you have the "Essential" morphs available in the Modify panel?
Waterlane Studios
Waterlane Studios
Visits: 308
Thanks for your replies If you see the pictures I've attached you can see I've already selected the 'input' option, but no map-image slots are visible... I've tried the verification process and it seems fine - and yes, the essential morphs are showing. :-( I'm adding this to the feedback tracker instead - cheers anyway.
7 Years Ago by
Waterlane Studios
Forum Admin (RL)
Forum Admin (RL)
Visits: 729
If you only have CC Essentials Morphs & Skins then you will only have Input maps available for the Actor Skin.
If you need access to Input maps for clothing then you also need the CC Essential Clothing & Fabric pack.
Waterlane Studios
Waterlane Studios
Visits: 308
Forum Admin (RL) (5/23/2017) If you only have CC Essentials Morphs & Skins then you will only have Input maps available for the Actor Skin.
Hi - thanks for the answer. you may be right as I don't have that pack installed... How though could I add a decal (eg tattoo) onto a characters skin? I cannot see an "input" option under the body decal. and, for example - If I go to the 'Misc/Body Hair' tab then I can choose 'Input' but the map option still does not show...
Waterlane Studios
Waterlane Studios
Visits: 308
... I cannot see any option to 'use maps' under any body 'input' option - eg Decal on the body or head.???
Forum Admin (RL)
Forum Admin (RL)
Visits: 729
You should see input map options for decals when you have it selected as shown below.
Waterlane Studios
Waterlane Studios
Visits: 308
Thanks for the screenshot - the input maps are not showing up for me though (here's my screenshot to show you...)
Forum Admin (RL)
Forum Admin (RL)
Visits: 729
I would advise reinstalling the CC Essentials Morph & Skin pack as clearly something isn't right. Once complete check the log to see if it completed successfully. It might indicate if there has been a problem during install.
