Hi Miranda,
Its not confusing that the path is set when the developer creates the slider. After all, it makes perfect sense that a eye morph slider couldn't be moved under the "leg" section for instance.
What's confusing is how the sub-folder paths are handled. Naively I thought the MarketPlace Edit Item section had some "authority" over these sub-folder paths and that whatever you put there would be reflected in the installed product. Actually, it is, but partially. The sliders *files* are properly installed into the Template/AvatarControl/ and sub-folder paths set in the MarketPlace, but this is not reflected into the CC interface sliders hierarchy.
That's why I posted this issue because I believe CC should take into account in which sub-folders the slider files are installed and 'expose' the sliders in the interface sliders hierarchy accordingly.
Now I'm confronted to a new issue: How do I edit those sub-folder paths in the product if I don't have access anymore to the original sliders I created.. ? : )
guy rabiller | GOETZIWOOD STUDIOS
"N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
7 Years Ago by
grabiller
