GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
Hi, Does anybody else has the same issue: Whenever I send a 3d Head to CC then my v1.5 of CC is summoned instead of the latest installed version (2.1) even if CC2 is open and launched CT8 in the first place.
-- guy rabiller | GOETZIWOOD STUDIOS "N.O.E." (Nations Of Earth) Sci-Fi TV Show, Showrunner.
duchess110
duchess110
Posts: 2.0K,
Visits: 15.5K
grabiller (5/16/2017) Hi, Does anybody else has the same issue:
Whenever I send a 3d Head to CC then my v1.5 of CC is summoned instead of the latest installed version (2.1) even if CC2 is open and launched CT8 in the first place.Yes I can confirm even if CC2 is open CT8 launches CC1.5 So I save and export the Head from CT8 to somewhere I can access it and then open CC2 and Import the Head.
Duchess Designs Store
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
@duchess110 Yep, that's what I do too. I actually save the heads in Shared Custom -> RLHead which is a folder apparently created by one of the installed software (perhaps CT8 itself). But I believe it does not really matter. On a side note, do you always get 2k textures embedded in your RLHead ? Or are those 1k ?
7 Years Ago by
grabiller
duchess110
duchess110
Posts: 2.0K,
Visits: 15.5K
I went and used the same head that I did the above test with and I have a 1k image that opens in Photoshop.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
Thanks.
GOETZIWOOD STUDIOS
GOETZIWOOD STUDIOS
Posts: 1.2K,
Visits: 7.2K
FYI: FT 2270 - CT8 Calls CC1.5 Instead Of Latest CC Installed Version
Last Active: 14 hours ago
Posts: 15.7K,
Visits: 30.5K
I assume this requires an update of CT8 as CC 2.0 only recently became "official".
Posts: 15.7K,
Visits: 30.5K
To follow up on this, my guess is that CT8 will be updated once IC 7.0 is released officially. In the meantime, as response to a similar question, I posted a workaround here: https://forum.reallusion.com/FindPost326320.aspx.
ian_11
ian_11
Visits: 2.0K
Seems like this has not been done? Any one know if they are going to fix this? animagic (5/19/2017)
7 Years Ago by
ian_11
Clark
Visits: 7.3K
I had the problem initially, but I upgraded CT8 pipeline to 8.12 in October and no longer have the problem.
7 Years Ago by
Clark
