3d test / Rampa method of changing character clip orientation works in z direction
Posted By Anaximander 7 Years Ago
3d test / Rampa method of changing character clip orientation works...
Anaximander
Anaximander
Veteran Member (912 reputation)Veteran Member (912 reputation)Veteran Member (912 reputation)Veteran Member (912 reputation)Veteran Member (912 reputation)Veteran Member (912 reputation)Veteran Member (912 reputation)Veteran Member (912 reputation)Veteran Member (912 reputation)
Posts: 31, Visits: 788
This may be common knowledge, but in case it isn't I throw it out there for everyone's use. If you need a character to run up a slope the methods used by 3d test and Rampa also work in the third dimension. Just rotate about the x axis instead of the z.
