If you download via the Reallusion downloader from the web, you can specify which version it is installed in. If you download it and install from Windows Explorer, you may need to make sure its path is to CC2.
Everything works fine in CC2. The skin can be set to use PBR materials, and will work fine with the Appearance Editor.
7 Years Ago by
