Hi. I've contacted and have talked with the tec support over at Noitom but I'm not having much luck. I'm trying to install the latest software for axis neuron but I keep getting the same error message whenever I try. Noitom suggested I use a forced uninstall program for the version that was there ( it wouldn't uninstall normally ) , and when that didn't work they gave me some steps for going into the regedit window but that didn't work either. I've provided what they suggested and I'm also supplying a screen shot of the error message I get. I think the problem might be a deleted folder in the APPData folder that the installer can't find. But I don't know how to fix this problem.
Thanks.
From Noitcom;
Visit your Registry Panel
1)WINDOW Button + R
2) Type:
regedit on the command line
3)Registry Editor will show up
4) Navigate to HKEY_CURRENT_USER
5) Search for the SOFTWARE folder
6) Right click and select Delete on the folder
This will remove any registry files under Axis Neuron or NOITOM. The
motion file folder where you have saved your previous motion captures will not be affected during the removal of Axis Neuron.
Once these steps are done you may reinstall Axis Neuron.
( I assume they meant delete any folder with Noitom and not the entire software folder ). one way to remove the older Axis Neuron and is to download an UNINSTALLER app; to completely remove
all traces of the previous software.
Then, you can go ahead and restart the computer and download the new version of
Axis neuron Pro.We hope to hear back from you.
Regards,
Perception Neuron
Sales and Support Department
