3DXChange to UE4 animation fps mismatch. How should I export?
Posted By notintricate 7 Years Ago
notintricate
notintricate
Senior Member (346 reputation)Senior Member (346 reputation)Senior Member (346 reputation)Senior Member (346 reputation)Senior Member (346 reputation)Senior Member (346 reputation)Senior Member (346 reputation)Senior Member (346 reputation)Senior Member (346 reputation)
Posts: 3, Visits: 103
Hi
I have a character with motionplus facial animation which is 16frames long.
I've exported it to FBX via 3DXchange.
Then I imported it to UE4 and I get timeline twice shorter than needed - 8frames
Animation Length - Animated time
Use Default Sampling rate - checked on.
As far as I understand — iClone works at 60fps that's why I get half of range at import. (I set up 60fps scene in maya and imported it there and it seems to work)
But inside UE4 if I uncheck "Use Default Sampling Rate" it still doesn't import properly! It gives me 10 frames timeline when I export from 3dxchange at 30fps sampling rate. And it gives me 17 frames when I export from
I tried to export from 3DXchange at 60fps with no luck. Still getting arbitrary timeline length.
To summarize: it drives me crazy!
All I want is to have exactly 16 frames of animation inside UE4 perfectly matching iclone 16frames animation.
Any help is highly appreciated. Help me to figure out the proper export pipeline, thanks!
Snarp Farkle
Snarp Farkle
Posts: 770, Visits: 3.6K
That's a good question, I'm just getting started with Unity for now but I found a lot of answers on RL's YouTube channel [HERE]
notintricate
notintricate
Thanks, but still it would be kinda workaround, and I'd like to get understanding of underlying reasons for why that mismatch is happening.
Jfrog
Jfrog
Posts: 696, Visits: 4.7K
But inside UE4 if I uncheck "Use Default Sampling Rate" it still doesn't import properly! It gives me 10 frames timeline when I export from 3dxchange at 30fpsfps sampling rate sampling rate
I just found out this thread and while I don't know much about Unreal engine I know a bit more about audio (sample rate).   I think your are confusing two different things. Sample rate has to do with the sound, more precisely how many sample of an audio waveform is being sample in a second. The standard in video is usually 48Khz. So the default sample rate would be checked or unchecked to match or unmatched the audio sample rate and not the FPS which is the number of frames per second and video related.
Hope that helps!
Horror Stories in VR
Immersive Sound VR
7 Years Ago by Jfrog
