Greetings all:
I have spent the last 3 months of my life trying to get CrazyTalk 8 (first standard now Pro) to run successfully on my setup. I am working with tech support but hoped maybe others might have some suggestions since they are so slow to respond (which I get at this price point...not complaining just saying...).
The issue is that in a dual monitor mode at some point the dialogue box for importing/creating a script stops showing up. Every other dialogue box still displays except the one where you select talk or listen mode. It took us months to figure out what was happening and now we can't seem to stop it from happening over and over again. Obviously a bug, but still very frustrating as I keep losing a couple of weeks at a time of being able to use the software while the problem gets fixed again.
To make matters worse, before I could fix the problem by de-installing and re-installing without the second monitor attached but now that isn't even working. So the million dollar question...
Are any of your running in dual monitor mode? Are you seeing this problem? If so, what have you done to fix it...
I should add that I am running Windows 10 on a Surface Pro 4 using a Sharp flat screen as an external monitor...
Thanks in advance for your help as always,
Joel (Nashville)
7 Years Ago by
joelnann
