MattCoombs
MattCoombs
Last Active: 7 Years Ago
Visits: 17
Hi. I am a new user to CTA and I am attempting to bring in a character from the flash template. every time I bring in the character its a trainwreck. When I import it there are tons and tons of elements all over the place. and its different for every angle. Im not sure if this is an issue in Animate CC (flash pro) or if its with CTA. Please Help!
toonsunlimited
toonsunlimited
Visits: 4.3K
Looks like you are trying to import just a single angle. Is that the case?
MattCoombs
MattCoombs
Visits: 17
No. We set up the template for all angles except top and bottom. It would be ideal to have all the angles imported.
toonsunlimited
toonsunlimited
Visits: 4.3K
You need to add the top and bottom angles or it will not import correctly. You can quickly test it out by simply copy the G2 Templates version of the Top and Bottom to you files and importing it into CTA. But ultimately you will need to do a Top and Bottom for a G2 Character.
MattCoombs
MattCoombs
Visits: 17
The top and bottom angles are in the template. we just didn't do any modifications to them in the template. so they are importing with it.
I get no errors as far as the sprites and pivots go on the import. but yet I end up with this. Is there something that can happen in Animate that would cause this to import like this?
toonsunlimited
toonsunlimited
Visits: 4.3K
I make a lot of G2 Characters. Normally if I see something like this, it's due to a sprite being copied into another angle, but symbol was not renamed to match the new angle. If you want, you can send file to askjanell@toonsunlimited.com and I can take a look at it. Janell
MattCoombs
MattCoombs
Visits: 17
Thank you! I just sent you the file.
toonsunlimited
toonsunlimited
Visits: 4.3K
I have received the file and glance over everything. I will do a video to show you how to resolve your issue.
toonsunlimited
toonsunlimited
Visits: 4.3K
This video explains everything you need to do to resolve your problem. If you have question on how to use Crazytalk Animator, I can be reached askjanell@toonsunlimited.comDon't forget to subscribe to my YouTube Channel!
