oldblock
oldblock
Visits: 55
I need to edit and/or delete the audio track. The tools have no effect which I assume is because no audio has been selected. I can't find any way of selecting or highlighting the audio. Help please.
Last Active: 4 hours ago
If you open the Timeline you can click to select the audio on the Voice track (it will turn red). You can then hit Delete on your keyboard to remove it or right click to see the available options such as Break, Rename, Lip Options etc.
oldblock
oldblock
Visits: 55
Thanks. OK I've discovered the timeline and selected the voice track which turned red.but hitting delete key has no effect and right click only gives me one option 'Rename'. Are we talking about the same software? I'm running Crazy Talk 8 Standard 8.1.2024.1 Cheers, Ray
Hi Ray, Unfortunately with CrazyTalk 8 Standard you only have limited Timeline functionality. You get more options with the Pro and Pipeline versions and support for multiple audio tracks. Please see the differences between versions HERE.
osfield
osfield
Last Active: 7 Years Ago
Visits: 3
I have the same problem. I think your answer was pathetic. You should be able to break or delete the timeline in standard as the manual indicates. The Function box only comes up with greyed ut options and audio wont highlight. It simply wont work. I am very disappointed in this software all up .
