GreedyPeopleSuck
GreedyPeopleSuck
Visits: 357
I want to import my model from ZBrush into CrazyTalk8 but I am having a nightmare of a time. I can get a non-standard rigged iAvatar via 3DXchange into iClone easy enough, but I can't figure out how to get my model into Crazy Talk 8. The Character Creator doesn't import FBX for some reaosn without a key (whatever that is), and it doesn't import the iAvatar I made. It's very unclear (as with most things in RA software), how to proceed. https://www.youtube.com/watch?v=WOXncXsft10 This tutorial very unclearly glosses over something that's pretty important. :-) Any idea?
Posts: 10.8K,
Visits: 40.2K
Not possible . Like the message says, in your another post only CC Character . That mean not own Charactermesh , only morphs made from CC Mesh
The Character Creator doesn't import FBX for some reaosn without a key (whatever that is) if you export a CC Character as FBX , CC will created a FBX key too , that key is needed if you create a morphslisder or conforming Clothing .
GreedyPeopleSuck
GreedyPeopleSuck
Visits: 357
vidi (12/11/2016)
The Character Creator doesn't import FBX for some reaosn without a key (whatever that is) if you export a CC Character as FBX , CC will created a FBX key too , that key is needed if you create a morphslisder or conforming Clothing . So what exactly is the workflow for converting my models to be used in Crazy Talk? It can't really be to resculpt my portfolio...right? I get sort of the reason they wouldn't want to do some weird morph, it's a complicated, suboptimal way of implementing an auto-rig, but why would you need a checksum key to import? Do you see this changing in iClone7?
Last Active: 3 hours ago
nadiak (12/11/2016)
Only CC based characters can be used in CrazyTalk 8. If you wish to use non-standard characters in iClone 6 then that is not a problem as you can import them as such using 3DXchange 6 Pro or Pipeline. For CrazyTalk 8 the only option for your 3D portfolio would be to render images of them and create 2D characters from the rendered images. Then they could be animated in CT8. But as 3D heads it's not possible I'm afraid unless they are in CC format.
