eternityblue
eternityblue
Visits: 2.7K
From https://www.reallusion.com/event/iClone7-preorder/Pro no longer can export OBJ files. Is that correct? Will I still be able to load up v.6 and export OBJ's?
My system: i7 3770 Gtx1060 6GB
Last Active: 29 minutes ago
Visits: 60.6K
That is an unknown at this point. The chart for 6 showed the same thing, if I recall. It did retain the export/replace object ability though (which is OBJ). We'll just have to wait and see on that one.
In the current release, you cannot export an OBJ without having an export license if it needs one.
eternityblue
eternityblue
Visits: 2.7K
Yeah, but that is true with the Pipeline version as well, you still need to have proper rights to export. I'm ok with this being the new reality, it makes more sense that pipeline means full export of all assets, but still, I paid for functionality and I'd like to still use it in 6 as much as I can. That's my real concern.
Posts: 15.7K,
Visits: 30.5K
eternityblue (11/26/2016) Yeah, but that is true with the Pipeline version as well, you still need to have proper rights to export. I'm ok with this being the new reality, it makes more sense that pipeline means full export of all assets, but still, I paid for functionality and I'd like to still use it in 6 as much as I can. That's my real concern. The chart contains errors as I mentioned elsewhere (e.g., it doesn't mention import of iClone formats), so it can't be taken seriously at this point. This is a long-standing recurring problem with RL published materials. They should really hire a proofreader.
JIX
Posts: 1.1K,
Visits: 1.3K
Actually you should report this issue to (in?) the Feedback Tracker. No kidding!
8 Years Ago by
JJJAM
Posts: 15.7K,
Visits: 30.5K
I give up, sw00000p! You stick with your opinion, I stick with mine... Peter, could we have some clarification about the faulty chart?
8 Years Ago by
Its still early days and some things have yet to be finalised but I will try to get clarification on this and let you know.
Visits: 60.6K
Just confirmed in another post from Peter.
"The export features in 3DXchange 7 will be roughly the same as 3DXchange 6. For full compatibility with iClone 7 you will need 3DXchange 7 as 6 will not be able to open any iClone 7 content. However you will still be able to use 3DXchange 6 to send content to iClone 7 just not the other way around.
For the OBJ question, you will still be able to use CC to export OBJ and use the "Replace Mesh" feature with 3DXchange 7 Pro, but for FBX, BVH, Alembic, Camera export and PBR export you will need 3DXchange 7 Pipeline."
