dickymac
dickymac
Last Active: 8 Years Ago
Visits: 63
I've been trying to do some really basic edits; I'm using a very clean audio file and a simple head image of the dog and nothing else.
Using the, Lips Editor, I've been trying to make adjustments to where the phonemes should go.... adding, taking them away, or adjusting where needed.. I then wanted to see the result, but simply playing back the piece I'm working on..... totally frustrated! Such a wasted Morning!!
Check out the video...
Either this is the normal situation with CT, or I'm being unlucky with the software that RL have provided.... Comments Please!?
Posts: 22.6K,
Visits: 35.6K
It certainly isn't normal and not an issue we have other reports of. This seems related to the CPU issues you have reported in other threads. Sadly until you can get this CPU issue resolved then you will keep encountering problems. As I mentioned in other threads you will need to work with Technical Support to try and find the cause of these issues which do seem system specific. Unfortunately I'm on the Windows side so can't really help much with Mac issues but Technical Support should be able to offer some help with these problems you are having.
dickymac
dickymac
Visits: 63
It certainly is taking a toll on the cpu!
Technical department seem to be struggling too!
Replaced Standard version and the gave me pro version to try, but just the same.
Apple engineer from Solihull checked system this morning and running as should. Activity monitor shows it is a software error.. memory location possible!
If not sorted by tomorrow I will uninstall and ask for refund.
Thanks for your time
Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
dickymac (10/27/2016) It certainly is taking a toll on the cpu!
CT 8 is not the problem.... """Kernel task"""" is your issue Google: kernel task high CPU usage Here are some links to get you started Apple official thread https://discussions.apple.com/thread/6452727?start=0&tstart=0Other: http://blog.viktorpetersson.com/post/100148585299/how-to-fix-kerneltask-cpu-usage-on-yosemiteOther: https://support.apple.com/en-us/HT201295Cheers
Freelance Artist Kevin.S
Email: animatemyart@gmail.com - Web Site: www.animatemyart.com
8 Years Ago by
kevin.S
dickymac
dickymac
Visits: 63
Hi Kevin and thanks for the input..
The Kernal is using 14% so not high... over 150% would be considered excessive!?
Kernel problems have already been eliminated by service engineer. Mac had a complete reinstall to solve any third party problems.
I don't have any other issues, with any other program I run.... only CrazyTalk!? So you still say that this is not related to CT?
Many thanks for your time!
