unislibre1
unislibre1
Last Active: 6 Years Ago
Visits: 19
I just downloaded and installed CTA pipeline and then the recommended 2.15 patch. Upon opening the program, it opens half off the bottom of the screen of my laptop, with the smaller Red splash-screen window on top of it that offers 4 options, also half off the screen. Because of this, I cannot close the splash-screen window(close option is off screen), and I cannot move the program window without closing the red window first. I know there is a check box that gives the option to not show this red window again, but that checkbox is also off screen. Does anyone have a suggestion on how to remedy this? Any suggestions would be appreciated.
theschemer
theschemer
Posts: 1.4K,
Visits: 2.9K
Try right clicking on the bottom task bar and use one of the options in the list. TS
8 Years Ago by
theschemer
zeeshanafzalkhan
zeeshanafzalkhan
Visits: 10
In Trial Version I cannot work on as Splash Screen of Update is appearing need solution to Test & Purchase Software afterwards .
Last Active: 33 minutes ago
zeeshanafzalkhan (11/6/2016) In Trial Version I cannot work on as Splash Screen of Update is appearing need solution to Test & Purchase Software afterwards .
This problem is normally that the close button on the splash screen is outside the viewing area of your screen. However this can normally be resolved by simply hitting the Enter/Return key on your keyboard once CTA launches. This will close the splash screen where you will be able to maximise the window to fit your screen. Do give this a try and see if it resolves the problem.
