OK folks, so close to my 3D Frankenstein model. I just can't seem to find a way to add the bolts to the neck.
I'm guessing I have to have some 3d structure on the neck to texture? I have tried just editing the textures. but the bolt textures just lay flat on the surface. I can't get them to stick out from the neck.
Here is my CT8 project, and the 2D image I used. The most identifying feature on ole franky, are the neck bolts. You can see, it didn't turn out too bad, I just need the neck bolts, and I'll be all set.
Yes, I know I can use the 2D image, for my purposes; the 3D will work better. Does anyone know of were I might find a 3D model of Franky? That might be easier to use.
Any help appreciated. I have done some more editing as well, this project screen was taken earlier in my project. Thanks for any help
Best,
David
