Hi Rampa,
I work with Autodesk Maya (which also has animation layers). I can successfully clean motion capture data produced by the PN gear. Though the main issue here is production speed, and as you all know; one of the most important things in your workflow is production speed. The discrepancies are so bad that it more than triples the amount of work I have to put in cleaning the data. Unnecessary work... Respectfully... I have tried many things like changing the bone orientation in Maya on the exported motion capture data itself to correct the faulty bone alignments. Though this doesn't work, since with each separate recording (or during), the bone alignment shifts because of either unstable syncing or other potential things that could go wrong. These problems are almost unnoticeable and the slightest twitch could create a massive difference. The orientation fix only solves half the problem or sometimes even makes it worse.
I guess now it's easy to understand that it would improve workflow immensely if we could change the orientation 'directly' before a mocap recording. Having this amount of control beforehand means preventing issues that could tangle up together and create an even bigger problem.
Another reason to stress this feature is needed, is by looking at recordings where a two-handed prop is involved (like a weapon). It is nearly impossible and extremely clunky to perfect a motion capture act by letting the live actor create the offset himself. He can hold the object still with one hand whilst using the other hand to create the offset to compensate for the bone that is faultily aligned. Though holding a two-handed object with one hand makes the act seem extremely unnatural and almost impossible to do adequately. This would again create a lot of extra work.
You could say that this is a calibration issue (it definitely is). But calibration is an automatic feature in Axis Neuron. Every time calibration is performed to correct a specific limb (feet, hands or even a single finger) something else gets broken. This is why manual calibration would fix all the trouble. But I don't see PN working on it since they are busy with other stuff. This is why I'm considering buying the iClone 6 software package.
Any help would be greatly appreciated.
Edit: I am aware of all the possible options in the Axis Neuron software being the owner of a Pro License. None of the available options solve this issue.
8 Years Ago by
3David
