Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
Lisalulu
Lisalulu
Visits: 151
I really like these ! good work Kevin I see you posted new ones on youtube the ape one is cute.
Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
Alien Maniac
Alien Maniac
Visits: 2.1K
very cool work!
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
Lisalulu
Lisalulu
Visits: 151
Looks amazing a whole scene built around a video clip now that's a good technique!
toystorylab
toystorylab
Posts: 4.4K,
Visits: 28.8K
The waterfall looks very good and quite realistic, how did you do that???
Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
toystorylab (7/16/2016) The waterfall looks very good and quite realistic, how did you do that???
I took a video and made a plane then I built the scene around the video plane. If you drag a video into iclone with the left mouse button you get a choice add as billboard plane etc, add it as a plane, it takes the video an puts it on a thin square.Then you can move it around resize it etc. This is what I did and simply built my scene around it to blend it in and make it kind of look like part of the scene. over all it saves lots of time in setting up scenes. The monkey video also has a plane created background, its a picture of a jungle at the start of the video, behind the ape.After the ape takes the turn there is another picture plane behind the 2 tree's in the background. I built the jungle in front of the images to save time. Hope some of this makes sense. cheers
Freelance Artist Kevin.S
Email: animatemyart@gmail.com - Web Site: www.animatemyart.com
8 Years Ago by
kevin.S
toystorylab
toystorylab
Posts: 4.4K,
Visits: 28.8K
AAAHH I was quite sure these were no "standard" waterfalls, and found it a bit "blurry" to the rest of the scene but never tought it was a video-plane ;-) Does anybody know if there are some better waterfalls than the "standard" waterfall available? I need a waterfall for my current project...
Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
toystorylab (7/17/2016) AAAHH I was quite sure these were no "standard" waterfalls, and found it a bit "blurry" to the rest of the scene but never tought it was a video-plane ;-)
The water system does need a big upgrade its a vary basic water system not vary usable unless you just make a lake or pond. Even then you can see the polygon break lines in the water. If you look close at the waterfall video I made, you can see the break lines in the water near the bottom of the video.Might have to go full screen to see them but they are vary noticeable. cheers
8 Years Ago by
kevin.S
Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
