tylert113
tylert113
Last Active: 8 Years Ago
Visits: 11
Crazytalk8 would not import realheads, so I tried loading the heads into the RealIllusion folder in my program files. They still wouldn't load. In the meantime all of the other folders with actors heads disappeared from the RealIllusions program folder, so I am now reinstalling the Crazytalk8 program after uninstalling it. I checked for help, but there didn't seem to be a solution offered. What am I missing? Thanks for your help.
Last Active: 27 minutes ago
Please first make sure you are using the latest version of CrazyTalk 8 which is 8.03. RLHeads will not work with versions of CT8 prior to 8.02. You can check and update by going to Help > Check For Update in CT8. Then do make sure you have a CT8 3D Actor loaded first. Now try dragging one of the RLHeads from the folder below onto the CT8 3D Actor. Does this apply the RLHead onto the actor? If not, please explain what happens. Do you get an error message? If so please post a screenshot showing the error message. Thanks. C:\Users\Public\Documents\Reallusion\Shared Templates\RL Head\Realistic Human 100
tylert113
tylert113
Visits: 11
Thanks so much for responding to my inquiry. I have the 8.03 version of CrazyTalk 8. And when I followed your directions, the program worked as advertised. Thanks again..
