kirkshoe (4/15/2016)
Is it possible to import and apply your own face/head images with "Realistic Human 100" heads in Crazytalk 8 pipeline?Yes you can do this.
You will need to first use your own facial image to create a CT8 head and save it. You then have two ways to proceed.
The first is to export your CT8 head as RLHead from File > Export.
The second is to go to Create > Texture Settings and save your head and body textures as image files.
Then you can load up one of the "Realistic Human 100" heads and then drag in your own saved RLHead choosing "Import Texture" only (see below). Alternatively you can go to the Create > Texture Settings again and load your saved face textures.
