i went through my old notes on this
and forgot i used another maxscript
which baked the modifier stack into keyframes
not that this will help you, but in case
swOOOOOp wants it
here it is.
bakes the vertices from the modifierstack to a keyframed editablepoly
fn bake obj progBar =
undo on
try
local start = animationRange.start as integer
local end = animationRange.end as integer/160
local vertSels = #()
local vertPos = #()
local startT = timeStamp()
if classof obj.modifiers[1] != Edit_Mesh then modPanel.addModToSelection (edit_mesh())
if obj.selectedVerts.count == 0 then polyop.setVertSelection obj #all
local progUpStep = 50.0/((end-start) as float)
local progUp = 0
for t1 = start to end do
local curVerts = #()
local curVertsPos = #()
at time t1
for i in obj.selectedVerts do
local vert = i.index
local pos = obj.verts[i.index].pos
append curVertsPos pos
append curVerts vert
append vertSels curVerts
append vertPos curVertsPos
progUp += progUpStep
progBar.value = progUp
for m = 1 to obj.modifiers.count do deleteModifier obj 1
animate on
for t2 = start to (end-1) do
local oldPos = #()
at time t2
for i in vertSels[t2+1] do append oldPos (polyop.getVert obj i)
polyop.setVert obj vertSels[t2+1] vertPos[t2+1]
if t2 > 1 then
at time (t2-1)
polyop.setVert obj vertSels[t2+1] oldPos
local endT = timeStamp()
print("Time: " + ((endT-startT)/100) as string + "ms")
--progressEnd()
catch("Something went wrong")
function sel_filter obj = selection.count == 1 and classOf selection[1].baseobject == Editable_Poly
try(destroyDialog mainRollout ) catch()
rollout mainRollout "Bake!"
label descLabel1 "Bake vertices pos"
label descLabel2 "from modifier stack:"
pickbutton pickButton "object: " width:80 filter:sel_filter
button bakeButton "Bake!" width:80 enabled:false
progressbar progBar color:green
local bakeObj = undefined
on pickButton picked obj do
bakeButton.enabled = true
pickButton.text = obj.name
bakeObj = obj
on bakeButton pressed do
bake bakeObj progBar
createDialog mainRollout 125 130
clearListener()
8 Years Ago by
budbundy
