Cricky
Cricky
Posts: 2.8K,
Visits: 13.8K
iClone6 Simple Plane Prop to Scroll Text Across the Screen: Could be referred to as a Ticker Tape, I suppose. This was a very simple prop to create: It will not help the original need for a Ticker tape by a user who needed it for CTA, unless they also have iClone6. I have no idea what CTA accepts for props. This is a Simple 2 face plane... but the UV allows scaling to basically any size, and still get clarity when used as a ticker tape across the screen.
You just have to time out the movement across the screen or move the camera.
If you have 3dXchange it can be exported an OBJ and then used elsewhere. I have Scrolling LED Props that work on a different principle, but the text applied is limited. This plane accepts whatever size limitations your system has. 8192wx256h would look fine. This is the texture limitation in iClone. Font used is whatever your photo editor has.
SKYPE ID: rc.650
9 Years Ago by
Cricky
nlprod1
nlprod1
Visits: 4.5K
Thanks Cricky!
Lord Ashes
Lord Ashes
Posts: 1.3K,
Visits: 1.6K
Nice work.
Alternative Solution: If you can not move the plane or the camera, the solution is to scroll the UV on a static plane. This is what I did for my Electronic Sign in my store.
Cricky
Cricky
Posts: 2.8K,
Visits: 13.8K
As I said above: " I have Scrolling LED Props that work on a different principle, but the text applied is limited."
These work on the UV Offset principle. This prop was designed for simplicity, and is FREE, not a marketing opportunity for others. Lord Ashes (8/28/2015) Nice work.
SKYPE ID: rc.650
wendyluvscatz
wendyluvscatz
Last Active: 3 Weeks Ago
Posts: 2.5K,
Visits: 19.4K
you can also use image layer with an alpha channel video which is simply two one negative in opacity channel can make two with text captions in WMM or pan a camera along text on yours in iclone and render
9 Years Ago by
wendyluvscatz
