CaseClosed
CaseClosed
Visits: 781
If I want to export an iClone character or non-standard character with the armature (including face bones for facial animation) and the weight map for animation in Blender or another 3d animation software, can I do that with 3dxchange 6 pipeline software? I'm asking before I purchase the software because that's what I need it to do, and if it can't do that, then I don't want to purchase it. Thanks for any feedback!!
9 Years Ago by
bbvb17
duchess110
duchess110
Posts: 2.0K,
Visits: 15.5K
Hi Yes it is possible. Here is a YouTube video I did using iClone 5 and 3Dxchange5 a year ago, but the same would apply to Version 6 Hope it helps. https://www.youtube.com/watch?v=pX40UbdMhiQ
Duchess Designs Store
CaseClosed
CaseClosed
Visits: 781
I need to export the non-standard character with the armature and weight maps, including the facial armature. You said I can, and the video showed the figure successfully animating in 3ds Max, so I assume the armature (including face) came along with the character, can I export a non-character with a complete armature, including facial armature AND corresponding weight maps, from 3dxchange 6 pipeline into an FBX file?
9 Years Ago by
CaseClosed
duchess110
duchess110
Posts: 2.0K,
Visits: 15.5K
bbvb17 (7/31/2015)
Thank you for the reply I'm still not positive it can do what I need. I saw from the video that you can export a non-standard character with motions. That's cool, but I don't need to export motions. I need to export the non-standard character with the armature and weight maps, including the facial armature. You said I can, and the video showed the figure successfully animating in 3ds Max, so I assume the armature (including face) came along with the character, but I've learned my lesson to not assume when it comes to iClone products. To make a long story short, I'm asking you for a confirmation that I can export a non-character with a complete armature, including facial armature AND corresponding weight maps, from 3dxchange 6 pipeline into an FBX file. Thank you so much! Hi bbvb17 Again I will say yes. I personally have been able to do this with iC5/3dx5 as well as with iC6/3dx6. If you are not bothered about animation just put your Character in a T Pose in Exchange 6 and export as an fbx and uncheck export the animation option. I sometime do this and then inside Max the first thing I do is select all the bones and freeze transform. Then I can move the bones about to check if the weights may need a slight adjustment. Hope this info helps.
vidi
Posts: 10.8K,
Visits: 40.2K
I saw from the video that you can export a non-standard character with motions. That's cool, but I don't need to export motions. I need to export the non-standard character with the armature and weight maps A Bone can only deform (motion) a Mesh with a weigtmap A weithmap indicates the deform influence for the bone in the mesh , no weigthmap = no motion. So if you see in the video a non character with motion, this figure is guaranteed weight mapped, otherwise it could not move.
JC Weatherby
JC Weatherby
Visits: 802
I don't think this is really possible with Blender. When I attempted to import a CC Base Female into Blender - after exporting .fbx from 3DX6.2 - this is what I got: You should note that Blender stripped out all of the Texture Maps -- so it would be very much not fun to try to round-trip a CC through Blender back to iClone. I've run through all of the 3DX6 export presets (Unity, Unreal, Maya, etc...) - same results. If anybody has success with this, would you please show us a screenshot of your export settings in 3DX6? RL, YOU GIVE US NICE PIPES TO EXPENSIVE SOFTWARE, CAN YOU DO IT WITH FREE OPEN SOURCE SOFTWARE? Thanks!
9 Years Ago by
JC Weatherby
vidi
Posts: 10.8K,
Visits: 40.2K
In this case RL is powerless. If a FBX Importer is mess. FBX is not uniform
urbanlamb
urbanlamb
Posts: 1.2K,
Visits: 3.5K
JC Weatherby (9/11/2015)
I don't think this is really possible with Blender. When I attempted to import a CC Base Female into Blender - after exporting .fbx from 3DX6.2 - this is what I got: You should note that Blender stripped out all of the Texture Maps -- so it would be very much not fun to try to round-trip a CC through Blender back to iClone. I've run through all of the 3DX6 export presets (Unity, Unreal, Maya, etc...) - same results. If anybody has success with this, would you please show us a screenshot of your export settings in 3DX6? RL, YOU GIVE US NICE PIPES TO EXPENSIVE SOFTWARE, CAN YOU DO IT WITH FREE OPEN SOURCE SOFTWARE? Thanks! This is the blender plugin that is at fault and how its coded (not well) the person who coded it was more interested in unreal 4 engine and export from blender moreso then import. That being said if anyone has any spare time on their hands on the reallussion staff it would be cool if he could create a blender plugin that worked for import to blender fbx files without messing with em.
9 Years Ago by
urbanlamb
Visits: 60.5K
If the rigging/weighting is intact, all you need to do is rotate your mesh 90 degrees to match your skeleton. Do it in edit mode. Select all and rotate.
JC Weatherby
JC Weatherby
Visits: 802
rampa (9/11/2015) If the rigging/weighting is intact, all you need to do is rotate your mesh 90 degrees to match your skeleton. Do it in edit mode. Select all and rotate.Haha, I really don't want to have to go there That's no guarantee that it will arrive back in 3DX safely. And remember, all the texture maps have been ejected, and that's another headache.
