andrew.genaille
andrew.genaille
Last Active: 5 hours ago
Visits: 9.9K
Stephen Hawking sent out a letter warning about Artificial Intelligence, robots respond https://youtu.be/alIUAhV4qFkRobots take the Turing test, which is designed to convince humans they are talking to another human https://youtu.be/opq98KwKrL4<iframe width="560" height="315" src=" https://www.youtube.com/embed/opq98KwKrL4" frameborder="0" allowfullscreen></iframe>
Last Active: 4 hours ago
Visits: 60.3K
These are great clips you've made. Very funny, and a little poignant!
primaveranz
primaveranz
Last Active: 3 Weeks Ago
Visits: 1.2K
I loved these. I hope you make more
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
i'm reallly enjoying your theme / series, you write good scripts Somehow I'm reminded of the odd couple! BUT - start paying attention to details ...like when I can see the inside of the robots mouth and teeth, an obvious error!! That's distracting ....you are better off moving less, than causing distractions. Distractions will only water down your great script writing
I'm not going to be easy on you with my comments from here on, because you are obviously talented!
andrew.genaille
andrew.genaille
Visits: 9.9K
Thanks to all above, there's a few more on the way. As for the Critique... Yes, absolutely. Each one represents me testing out what I can and can not do with them; so I'm good with having things pointed out but I'm hoping it comes with help with how to fix things.The major things I'm fiddling with, as you can see from short to short, is the lighting and the paths (walking). I spend a lot of time going "where did that come from?" And judging how fast they move based on path lengths. Plus everytime they start and leave a path they vanish on me for half a second. You're right about the teeth, they drive me nuts when I see them and it's usually after rendering. Even after I preview. But that's me figuring out how the camera moves. A lot times though, I'm using camera moves (pan opening of "robots play would you rather") to hide things I couldn't figure out. Sometimes they work, sometimes it's "well, that's... Educational."
