Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Hello Friends, Here a clip to the current freebie in the German Forum (werewolf). I had begun the wolf even as a prop and thus a clip. Everything is still in rough draft. The second half is also a werewolf clip in preparation. Here the wolf is a DAZ Avatar. As I said: It is not yet cut and the sound is only temporarily there, because YT has once again criticized Copyright (Sound spite of a Free Sound CD) Greeting from Germany Werner (Posfrosch) PS: Everything done with IC 6. The render times were normal.
Posts: 4.8K,
Visits: 16.4K
Looks like you're getting a good handle on iC6 Werner!!! Way to go!!!
Nice!
Or should I say, "Scary and terrifying!"
jgrant
jgrant
Visits: 2.1K
Great stuff. A lot of really good material here. Consider using more close ups and variety in your camera positions. Actions scenes like this benefit immensely from editing every three seconds (or less) to add heightened drama to the scene. The value of select ECU's (paws ripping, teeth snarling) all add drama as well. Consider using music from 'Van Helsing' or similar to time the edit and then replace. If you're not selling the clip, rarely will you have any blowback from copyright holders and you can use the music for your own promo. Keep up the good work.
jgrant (7/7/2015) The value of select ECU's (paws ripping, teeth snarling) all add drama as well.ECU = Extreme Close-Up Good tips. Thanks.
Postfrosch
Postfrosch
Posts: 6.9K,
Visits: 18.4K
Thanks for your nice comments Greets from Germany Postfrosch
9 Years Ago by
Postfrosch
toonarama
toonarama
Visits: 1.3K
Great work - some excellent animation and direction and I particularly loked the lighting. Excellent freebie werewolf too!
