Varsha Discmedia
Varsha Discmedia
Visits: 784
There is a problem in stereo 3d output
When I use stereo 3d render (anaglyph/side by side/above below or dual stream) the problem is rendering only 50% of shot length
For Example
Timeline is 500 frames (30fps) when I export in normal without using stereo 3d its render 250 of 250 its perfect
But when I use stereo 3d output its renders 125 of 250 exporting 50% of shot length
Please go through yourself and please reply soon,
know one responding properly for this issue please help us to fix the issue
hattori kun
hattori kun
Visits: 4.1K
Peter (RL) (2/17/2015)
Thank you all for the reports since the release of iClone 6.02. This is much appreciated. I know some of you are concerned that the issues are not being recorded, but I can assure you that everything reported in this thread is seen by the development team and logged. If you have posted issues anywhere else on the forum, I would urge you to also includethem here (or a link back to your original post). This will ensure nothing gets missed. Hello, for me the exporting of duplicated textures resulting in gigabytes of duplicate files is a bug https://forum.reallusion.com/Topic225125-388-1.aspx#bm225596Iclone+Indigo+speedtree is a very powerful weapon replacing my need for Lumion 3D=$$. You will have attract a new market with this combo.But it needs to fixed because exporting process itself takes a very long time from Iclone.
45thdiv
45thdiv
Visits: 694
I have played around again with the sync drift. I went back to this because I saw in an iClone5 tutorial Kai showing how the audio play back could be slowed down by using the enter key instead of the space bar. Well that function is no longer in iClone6. Why did it go away? I hope it was because a new audio scrubber will replace it. :-) I also noticed that the drift only seems to happen when playback mode has "By Frame" selected. If I switch that mode to "Realtime" than no audio slip is detected. I have been running a loop on this play back just to see if I am observing things correctly, and I think I am.
MatthewPC stats: Intel Core i7-5930K Processor (6-cores, 15MB Cache, Overclocked to 3.9 GHz with Turbo Boost)
Windows 10 Graphics card NVIDIA GeForce GTX 1080 graphics, 8GB Memory - 16GB Quad Channel DDR4 at 2133MHz DirectX - 12
256GB SSD 6Gb/s main HD + 4TB 6kRPM SATA 6Gb/s Storage
9 Years Ago by
45thdiv
Last Active: 5 minutes ago
Visits: 60.6K
This is actually something I would consider a "functional" bug that goes back to version 4 (probably earlier).
The issue is with the automatic alignment of the "root" to the avatar's animation. It does a fantastic job of aligning the root with the avatar's pelvis, but it only aligns position. It seems like it really should align rotation as well. It would sure make transitioning between mocap motions and persona based motions work more smoothly.
If the pelvis is tracked and the root set to it's position for every frame, why was the rotation left out?
hattori kun
hattori kun
Visits: 4.1K
Here's the bug in Iclone indigo for speedtree. The only workaround that works sometimes is to turn on/off the layer of the trees in a preview not the camview. Hope this gets fixed.
mark
Posts: 4.8K,
Visits: 16.4K
This may just be my system but....when I turned off the GIZMO, which is a lot of the time, in iC5 the mouse cursor would change to reflect the gizmo "state" (Move,Rotate, Scale). Now in iC6 the "state" of the gizmo is only know when I hover over the selected object and many times the object is not in view on viewport/stage. I have to get the object in the field of view, hover over it and then I know what the cursor will be doing...I find this annoying especially with lights and it really slows down my work methodology ..maybe it's just me but this is yet another thing I would like returned to the way it was in iC5
Posts: 15.7K,
Visits: 30.5K
mark (2/20/2015)
This may just be my system but....when I turned off the GIZMO, which is a lot of the time, in iC5 the mouse cursor would change to reflect the gizmo "state" (Move,Rotate, Scale). Now in iC6 the "state" of the gizmo is only know when I hover over the selected object and many times the object is not in view on viewport/stage. I have to get the object in the field of view, hover over it and then I know what the cursor will be doing...I find this annoying especially with lights and it really slows down my work methodology ..maybe it's just me but this is yet another thing I would like returned to the way it was in iC5 I noticed the same, so it's not your system. I agree, the IC5 way was better.
Cricky
Cricky
Posts: 2.8K,
Visits: 13.8K
mark
Posts: 4.8K,
Visits: 16.4K
May have been mentioned but you can on longer use the "ALT" key to adjust the viewport/stage as you are creating a Path. Very difficult to lay out an animation path when you can't adjust the screen to see where you want to continue placing a path node.
lpatter
lpatter
Last Active: 8 Years Ago
Visits: 898
It is Official. I am beating a dead horse. I just watched the tessellation video https://www.youtube.com/watch?v=4MEWUUr7yUc Mine simply does not work. 1. The height and vector displacement props in the tessellation bonus projects are flat from the beginning and do not respond to the sliders (tessellation level and multiplier). I tried adjusting them on all channels. Nothing!!! Is it broken? I tried making a custom box and nothing works. I have been trying periodically for 2 months and I thought it must be a bug that needs fixing but I am not sure. now. Do I need to activate something? I keep asking about the tools that are not working and I get no response in the forum. So I made my own son-GUI kytool but I can't make tessellation work. HARDWARE: Lenovo Y50 (59428531) Gaming Laptop Intel Core i7 4700HQ (2.40GHz) 16GB Memory 1TB HDD None SSD NVIDIA GeForce GTX 860M 2GB 15.6" Windows 8.1 64-Bit
9 Years Ago by
lpatter
