gmccurdy
gmccurdy
Posted 10 Years Ago
Last Active: 10 Years Ago
Visits: 27
I was trying to use the brush in the Masking Tools window to add some lipstick to an area missed. I could brush it red, the spinning clock would run like it was working, then the red mask I painted disappeared and the lipstick is not applied.
Is this a bug with the masking brush, or some other way to make the brush work?
Tia.
GM
Posted 10 Years Ago
Last Active: 3 hours ago
Hi GM, The lip area is defined by the fitting tools. If you find you need to redefine the area for the lips you should go back to the "Fitting" tab and make adjustments to overall size there. The masking tool for lips only affects inside the area setup during fitting.
